GSXRunner
- 160
- 39
- Feb 24, 2013
Queens,
New York
Anyone have this happen to them before? You know how the timing belt is aligned with the outside edge of the cam sprocket and part of the teeth show after the inside edge? Well, when I started it up, the belt shifted so that it is now aligned with the inside edge and the teeth show on the outside edge. It started cutting a groove in the side of the timing belt from the pizza cutter edge of the tensioner pulley that it was riding on. The timing is still correct; it didn't jump any teeth and it is tight. I took it apart and figured maybe I just got careless and overlooked that the belt was riding on the pizza cutter, so I redid everything making sure the belt correctly installed. I just put everything back together, started it up and the belt moved back in that position. Now it could be that since there's a small groove in the belt, it caught that grove caused it to move back in that position (which would mean, just a new timing belt is needed), or it could be something else. I know I'll figure it out eventually when I take it apart again, but if anyone has had this happen to them, I'd appreciate hearing what happened before I tear it down and re-time it. I'd hate to see this happen again with a brand new belt.
