Windows stopped working...
Hubbell91Tsi
228
Feb 1, 2009
Bentleyville, Pennsylvania
Checked the relay and pulled and checked all fuses and they looked fine... Tried another drivers window switch and still nothing... I honestly have no idea what could be wrong. NO ITS NOT THE WINDOW LOCK BUTTON
Tell me more, were you messing with it, if the drivers side is unplugged neither one will work. Check the ground that is as important as the power, you do have 12v volts at the regulator right, if so then the ground or regulator has to be bad.
I was trying to put the windows down and then they both all of a sudden stopped working. wtf is a window regulator LOL.
the window regulator is the piece that the glass sits on. it will move the window up and down; the motor powers it. if its broken, the motor may be working; but you'll get no movement. Can you hear the window motor?
check the plug IN to your window switch. one of the wires probably got bumpped out. easy fix. this happened to me the other day. let me know if thats what it was. goodluck
