1up
Oct 24, 2011
Seatac, Washington
Hello all! Happy to be back after 5+ years! (still a probationary member, I see)
Anyhow, I purchased an engine that I now believe, after some research, came off a 1988+ Galant GVR4 Evo RS. that should have no more than 60k miles (sure looks that way). I would love to use that low-mileage transmission instead of my beat +160k stock tranny.
I felt it was easier buying used than rebuilding because I have little experience going that route.
I have a 1991 Eagle Talon Tsi AWD with the stock 3-bolt rear.
I have a transmission with the KW5M332 NPXV code.
Both transmissions have their respective transfer case.
Both transmissions' output splines have the same count.
I'm sure I can interchange the transfer cases if I wanted to but not sure if they match internally.
I can't see any difference in appearance on both transmissions aside from the stamped part numbers.
I don't have much info on the my USDM tranny.
My question?
I was wondering if this Galant VR4 Evo's W5M332 WQYK tranny would work in place of my NPXV tranny without blowing up the center differential. I am also okay with staggered wheels/tires if it comes bypassing the difference in wheel rotation.
I pulled the following info on the GVR4 tranny from another site (4gtuners?):
As per Forum from 4GTuners
Body Description Model Class "Vehicle Name Code"
PNC Part Name "Mitsubishi Part Number"
Part Specification "Front Ring Gear N"
"Ring Gear P/N" Dates Note1
"Diff Type" "Rear Diff Ratio" R&P Rear Gear Kit P/N
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy
MD995730 W5M33-2-WQYK
N=64T
MD733279 90081 to 92033
Standard front diff 3.909 Clutch LSD MB860149
some bad pics:
My question?
N=64T
some bad pics:
This took me 10 sec to find.
http://www.dsmtuners.com/threads/matching-gearbox-w-rear-differential.498521/
Short answer. No you cant use it as is.
My issue has been solved; I'll leave you with this list I found that may be of use to anyone looking at this thread:
As per Forum from 4GTuners. Good to know. You may need it one day.
Name
Code" PNC Part Name "Mitsubishi
Part Number" Part Specification "Front Ring
Gear N" "Ring Gear
P/N" Dates Note1 "Rear
Diff
Ratio" "Diff
Type" R&P Rear Gear Kit P/N
EVO1 2.0DOHC/MPI/AWD CD9A SNGF (GSR) 403 21060A M/T & Transfer Assy MD971898 W5M33-2-WQGE N=64T MD743362 92101 to 93113 Standard front diff 3.909 Clutch LSD MB860149
EVO1 2.0DOHC/MPI/AWD CD9A SNGF (GSR) 403 21060A M/T & Transfer Assy MD971899 W5M33-2-WQWE N=64T MD743363 92101 to 93113 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO1 2.0DOHC/MPI/AWD CD9A SNDF (RS) 403 21060A M/T & Transfer Assy MD971900 W5M33-2-WQYE N=64T MD743362 92101 to 93113 Standard front diff 3.909 Clutch LSD MB860149
EVO1 2.0DOHC/MPI/AWD CD9A SNDF (RS) 403 21060A M/T & Transfer Assy MD971901 W5M33-2-WQFE N=64T MD743363 92101 to 93113 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNGF (GSR) 403 21010A M/T Sub Assy MD973695 W5M33-2-WPGE N=64T MD743362 94031 to 94083 Standard front diff 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNGF (GSR) 403 21010A M/T Sub Assy MD973696 W5M33-2-WPWE N=64T MD743363 94031 to 94083 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNDF (RS) 403 21010A M/T Sub Assy MD973697 W5M33-2-WPYE N=64T MD743362 94031 to 94083 Standard front diff 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNDF (RS) 403 21010A M/T Sub Assy MD973698 W5M33-2-WPFE N=64T MD743363 94031 to 94083 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNGF (GSR) 403 21010A M/T Sub Assy MD974291 W5M33-2-UPGE N=63T MD744332 94091 to 95083 Standard front diff 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNGF (GSR) 403 21010A M/T Sub Assy MD974292 W5M33-2-UPWE N=63T MD744333 94091 to 95083 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNDF (RS) 403 21010A M/T Sub Assy MD974293 W5M33-2-UPYE N=63T MD744332 94091 to 95083 Standard front diff 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNDF (RS) 403 21010A M/T Sub Assy MD974294 W5M33-2-UPFE N=63T MD744333 94091 to 95083 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995445 KM225-1-PH N=58T MD726425 88021 to 89023 Standard front diff 3.545 Clutch LSD MB185307
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995571 W5M33-2-NPGH N=58T MD726425 89031 to 89093 Standard front diff 3.545 Clutch LSD MB185307
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995570 W5M33-2-WPGH N=64T MD733279 89031 to 89093 Standard front diff 3.909 Clutch LSD MB185313
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995598 W5M33-2-WQGK N=64T MD733279 89101 to 90073 Standard front diff 3.909 Clutch LSD MB185313
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995620 W5M33-2-WQWK N=64T MD737530 89101 to 90073 Front LSD Limited Slip Differential 3.909 Clutch LSD MB185313
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995730 W5M33-2-WQYK N=64T MD733279 90081 to 92033 Standard front diff 3.909 Clutch LSD MB860149
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995731 W5M33-2-WQFK N=64T MD737530 90081 to 92033 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
US spec TEL, 90 -> _w5m332np__, e.g. kw5m332npzs (unk casing #);
_w5m332npzs, mh8095
US spec TEL, 91 -> _w5m332np__, e.g. kw5m332npxv (unk casing #
US spec GVR4, 91 -> _w5m332nq__, e.g. _w5m332nqbm, kx9091
JDM (Aus) GVR4, type unk -> _w5m332nq__, e.g. _w5m332nqzk (unk casing#)
JDM (Aus) GVR4, 91 -> _w5m332nq__, e.g. _w5m332nqzk, Lh6282
JDM GVR4, year unk -> _w5m332nq__, e.g. _w5m332nqzk, ma6822
JDM (Aus) GVR4 Evo, year unk -> c51ph, e.g. c51ph, ?x9766
JDM GVR4, year unk -> c51ph, e.g. c51ph, hL4285; c51ph, sd7177
unk spec GVR4 RS, year unk -> _w5m332wq__, e.g. _w5m332wqge, qn6866;
unk origin (E39 VR4 written on it) -> _w5m332nr__, e.g._w5m332nrxc, ex6172
JDM ZR4, 89 -> c51ph, e.g. c51ph, hk9717
JDM ZR4, 88 -> c51ph, e.g. c51ph, cL0845
US TEL 1G 3/89 - 6/90 (shift link) -> w5m332npzs
US TEL 1G 6/90 - 2/94 -> w5m332npxv
US TEL 2G 3/94 - 6/96 -> w5m332npzt
US TEL 2G 7/96 and up -> w5m332muzt
US spec GVR4 to 4/92 -> w5m332nqbk
US spec GVR4 5/92 and up -> w5m332nqbm
US Galant GSX AWD non-turbo 6/89-5/90 -> w5m312vqzh
US Galant GSX AWD non-turbo 6/90-5/92 -> w5m312vqbk
US Expo 1G AWD -> w5m33_mn__??? (Anyone know?)
US Expo-LRV 2.4 AWD non-turbo 5spd -> w5m332nnxl
US Expo 2.4 AWD non-turbo 6/92-2/94 -> w5m332nnxl
US Expo 2.4 AWD non-turbo 5/91-5/92 -> w5m332nnxz
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
