Ludachris
Founder & Zookeeper
- 8,880
- 4,727
- Nov 12, 2001
Newcastle,
California
Which turbo will be sufficient for consistent 11 second times? I've recently decided on a big 16g, but will that be big enough to run 11s with supporting mods and decent tuning? Remember, this is for a budget street car, so any one purchase over $1k is tough. A big 16g will run about $700-900, which is about $300-400 less than the larger alternatives.
Of course, I'll need lots of practice to run these times, but, I just want to make sure that it's possible before the money is spent.
. But anyhow, when I had my mhi 20g on my gsT ( ran it for a couple months but just traded it for a h1c today) I logged 46.8 lbs/min airflow only at 22psi. Everything was dialed in perfectly. I thought it was wrong so I did more pulls and would still get between 44.xx and 46.xx lbs/min. It was in the down firing housing 2.5". The hot side was a 7cm unported. My mods are up to date in my profile and what I'm getting at here is how do you think I was able to log that much airflow? I see everywhere on the forums where it mentions it is hard to get that much out of a 20g. Oh and this was on pump 91 and meth injection my own blend of 70/30 meth/water. I was running about 18-19 degrees of timing up top. I wanted to go for the record but I thought I blew up my engine (ended up being a headgasket) and I just went all out on my 6 bolt block 2g head build. I'm just curious if those numbers could've been wrong. Hope I'm not blabbering and asking/saying too much.
