- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- HX35
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Intake: FMIC w/ custom 2.5" piping and TB elbow, Tial Q Bov, 1g throttle body, evo 3 intake manifold with thermal gasket, snow performance water/meth kit.
Exhaust: custom t3 top mount manifold, twin scroll 12cm hx35, 38mm turboxs wastegate, 3" custom SS downpipe ceramic-coated, apexi N1 catback exhaust (catless).
Fuel: Custom high flow fuel rail, 515 Fuelab FPR, walbro 400lph, Fuelab tank to rail 6an kit w/ fuelab filter, RC750cc injectors.
Misc: EGR delete, taboos vacuum delete, battery relocated, tucked radiator, C.O.P w/ dynatek ARC-2, Cruise control delete, A.C. delete, alternator relocated full wire tuck, FIAV delete, catch can w/ 10an valve cover fittings.
- Mods-Engine
- High mileage stock 7Bolt engine!!! Balance shaft delete, external oil cooler.
- Mods-EMS & Logging
- DSMLink V3 full on SD, Innovate MTX-L wideband, EVO prosport boost gauge, Innovate MTX-D oil pressure/temp gauge, cheap volt gauge, ecmlink boost by gear, HKS turbo timer, custom pc head-unit for logging and tuning.
- Mods-Drivetrain
- SS line from master to slave, OEM shifter, stage 3 competition clutch, fidanza aluminum flywheel, solid shifter cable bushings
- Mods-Handling
- DBA4000 t3 rotors, polyurethane motor mounts, stoptech ceramic pads, SS brake lines, GSX brake swap, unknown 17" wheels, front, rear and lower rear strut bars, Tein Flex Z coilovers, tubular upper control arms with camber kit, 225x45 tires
- Parts Wishlist
- AWD swap
- Background
- Owned since Oct 2011, completely stock, car was involved in a minor accident.
