Please Support Kiggly Racing
95DsManiac's Eclipse GST
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
GT42 Variant
Build Type
  1. Drag Race
Custom Built Billet 11Blade s400 71MM BW/
4" Vband Exhaust/
Custom 4.5"core 3" upper and 2.75" lower/
DNP T4 Divided 44v/
Hyper gate 45MM /
Rci 2200cc/
Magnus Cast V3/
Tial 50MM BOV/
Magnus 1000hp 10AN fuel rail/
A1000 10AN pump w/ stm rewire kit/
10AN SS feed w/ Fragola 10AN 40 micron ss/
8AN SS return/
A1000 AFPR 8AN/
Custom sumped 5GAL cell 2 8an feed-8AN return-8AN vent
Aeromotive WYE (2)8AN to (1)10AN
Black Top CAS/
Q45 throttle body revised/
Custom Oil Catch Can/
Full Wire Tuck AND Fuse Box Relocation/
Gates 1G Water Pump/
E85/
Polyurthane left and right mounts, solid aluminum front and back mounts/
Kirkey pro drag seat/
5PT harness/
Alternator relocation
Mods-Engine
Freshly BUILT LongBlock:
2g head:
Ferrea Competition 1MM valves/
Kiggly HP Beehive springs and retainer kit/
TopLine revised 3G Big Bore Lifters/
Kelford 280s/
Custom Port and Polish/
Kiggly HLA/
Head Bolt Holes Enlarged/
ARP Head Studs/
Oem 4 layer MLS/
Gates Racing Belt/
FULL Blue Printed 6 Bolt Block:
Wiseco 85.5mm 9:1CR PTW .0045/
Wiseco rings Top .022 & Bottom .026 Gapped By Me/
Eagle H-Beam Rods W/
ARP rod bolts/
Polished Crank/
ACL Race Series Main Bearings/
ACL Race Series Rod Bearings/
ARP Main Studs/
Fully balanced rotating assembly/
Kiggly Main Girdle/
More to come
Mods-EMS & Logging
DsmLink v3 Full/
AEM 50psi boost gauge/
Stewart Warner Oil Pressure Gauge/Sender/
Innovative MTX-L Wideband Kit/
GM Style OmniPower 4 Bar MAP Sensor/
GM IAT Sensor/
BliTz Dual TT with Peak and Hold Boost Feature/
Gizzmo MS-IBC 5 stage boost controller/
Prosport water temp-voltage
Dynatek Arc-2 dIS CDI w/ plug and play harness/
Xtremefire Coil On Plug System/
More to come
Mods-Drivetrain
New OEM TOB/
6 Bolt FWD Act Xact Flywheel/
Rigid 6 Puck/
Extreme PSI Extended Slave Rod/
New Front Axles/
SS Line From Master To Slave/
Symborski Solid Shifter Bushing Kit/
Brass Shifter Cable Bushings/
B & M short shifter/
Spare SHEP built trans w/ Wavetrac lsd
More to come
Newer K Sport Full Coilovers/
Weld Drag Lites 10x15 with MH 26x10.5 slicks/
Front Drilled and Slotted Rotors/
Ingalls Front Camber Kit/
STM Rear Camber Kit/
More to come
Parts Wishlist
Couple sponsors and to race the 2014 drag race season
1/8 Mile E/T
7.782
1/8 Mile MPH
97.480
Timeslip Video Link
Watch Video
Timeslip Photo Link
Timeslip Details
Track Name : Sacramento raceway
Nitrous : No
Fuel Used : E85
Vehicle Weight : OEM
Tires : Street Radials
Sponsored Car : no
369.0 lb/ft
95DsManiac
More in 2G DSM
Share this Vehicle
