Where does this wire go?
andrewjscott
326
3
Oct 16, 2004
Sidney,
as the title says, where does this go? It comes off the alternator. Car seemed to run fine without it, but I'd like to tie up loose ends....
Found another one. This one comes out of the bunch of wires that go to the fuel injectors. again, car seems to run fine without.
the 2nd one goes like right below the the intake mani on the drivers side just about 3 inches down from top on intake mani it took me a goood 30 min to figure it out when i put my engine back it. I remember that plug very well LOL. as for the first one i believe it goes on the power steering pump if i remember correctly. YOU seem to remember every plug and wire when youve taken your engine out twice. hope that helps.
i figured the one connector was for the AC, which has been removed. As for the p/s pressure switch, it looks like the connector on the pump is non-existant (looks like its been broken off). Can you fix just the pressure switch, without replacing the whole pump?
