Where does this wire go?
ChrisNelson
96
Sep 16, 2005
Bemidji, Minnesota
This wire is stemming from a group of wires on the bottom of the alternator. It is white/red I believe.
My best guess is that it connects to the oil pressure sending unit:
Does anyone have any input on this one? I think this is the last unidentified wire that I have before I can get my DSM on the road! :dsm:
Does anyone have a picture of the stock oil sender that shows exactly what is attached to the sender? I've never seen it other than what you see in the pictures here. I haven't even started the car yet!!! :coy:
The stock oil pressure sender has a flexible yellow 18 AWG wire with a special slide-on flat connector whose flat side slides over (on its flat side) the "top hat" pin on the end of the sender. The oil pressure switch (operates the oil light) has a flexible yellow/black 18 AWG wire with a special push-on end connector that goes over the terminal spade lug on the switch.
See post #4 for pic: http://www.dsmtuners.com/forums/showthread.php?t=17800
