What timing belt to buy?
dsmcoder
382
Oct 12, 2010
Havre, Montana
I just looked at my timing belt and there was a crack in it. I have a 1991 gsx and the last owner replaced the engine and I have no clue what engine it is. I bought this kit here Store Locator | NAPA Online but I'm not sure if this will work with it or not, I can always send it back.
Does anyone know if this should work fine or do I have to look at the engine and try to determine which one it is?
While I'm at it is there any other parts I should change when the timing belt is off?
The contitech or gates belt. (contitech is the OEM supplier for mitsu belts)
You can get a full timing belt kit for ~$80.
Get something other than the autoparts belt. Gates or contitech will be solid for you.
Ive tried the NAPA set. It lasted 1000 miles... Then bought a Gates and never looked back
Where is the best place to buy contitech, gates belt or oem belt kits? Should I replace my water pump also?
I got my Gates belt from parts dinosaur. They have great service, even included a print out of instructions.
I'd get an OEM or a Gates Timing belt had a NAPA timing belt that shredded with only 30,000 miles on it & after that I would never purchase another timing belt from them again so I replaced that Crappy NAPA timing belt with a Gates Racing Kevlar timing belt & it is a great choice imo.
I think I am going to get the partsdinosaur kit sense the belts are made by gates. Has anyone tried their water pumps, I was thinking about one from them too.
