What did you do to your DSM today?
Well I'll be darn @19Eclipse90 you hit the nail on the head with that one (the bolt was JUST barely at 3/8. If i moved it ever so slightly it would read 3/8 but just wasnt quite there so could be device error). Now I just need to source some studs haha. Also need to get new spacers because the ones that were on there are 4mm under OEM. Additionally, these injectors just have o-rings it seems, not insulators unless that's just how they are with using an o-ring in place of insulators and the slimmer spacers. Is this typical with aftermarket injectors or do they retain the OEM spec on spacers and use of OEM insulators?
Read the test sheet of my reman alternator from BBB/Wilson..
Anybody else have a sheet I can compare against? The ripple current seems excessively high, over double what I would have expected
Got the CAS on with the weirdly long studs. May hold off on the exhaust manifold just for clearance when putting the engine back in.
Also does anyone have the studs and nuts for the 1g thermostat housing? I've got washers
Oddly enough they are the same as exhaust studs. I have spares if you dont!
Eight years after buying the big boy IWG EFR turbo, and three years after getting the hot parts kit from Morrison Fab to make it work. I’ve picked up a low-profile wastegate actuator to tuck the canister as much as possible. It’s probably not going to fit with the stock rad where it is, but will it fit an Evo with a tucked Scirocco radiator and no cutting anywhere? A transmission will go back in and we’ll find out tomorrow.
Sat in it and rowed gears from the passenger seat. I haven't driven a manual since 2022 and it's eating me...
I didn't make any sounds but I did watch through the windshield the ends of the shifter cables go up and down
I can one up you. It’s been since like 2019 for me.
Located and pulled the OEM ECU that was running everything else while the Microtech took care of fuel and ignition. This wiring is worse and worse the deeper I get. Anyone got a 2ga engine harness? Haha
Charging the battery as we chat.....
Worked on interior, plumbed up the bay for wiring , and catch can. hooked up sensors in bay getting ready to finish up master cylider for the clutch soon.. Stripping valve cover for repaint, order 2k clear for stuff, and brembo decals.
I hid the Blue 92 in the shop, under the Impala SS that was on the lift. She is sitting UNDER that big ole beast but at least she didn't get beat on by the hailstorm we had last night (hence why I was charging the battery a couple posts back). I wish I had a picture, it is quite a sight. Maybe I will grab one when I get off work and add it to this post. :thumb:
Nice move. DSM quarter panels are atrocious to take hail damage out of. Don't specifically remember 1g's but 2g quarter panels damn near have no access to the top of the quarters at all.
"STACKED" Storage for small cars! :)
That Impala SS weighs about 4800 lbs but she is sitting on the locks of the lift. :thumb:
We had golf ball size hail all around our area and a couple tornadoes for kicks and giggles :oops:
These poor cars had to take whatever we got but thank God it was just pea size hail for us. Phew!!! 🙏
I FINALLY ASSEMBLED MY ENGINE, tack welded the timing belt metal cover plates that had split apart, painted them matte black to match the VR4 black cover, installed the new dimpled/slotted EBC rear Rotors, reinstalled the calipers, and had many Cola and Potayto Chips. Umaru!
This. :)
Woot! Also discovered that one of the two short tcase bolt holes is stripped clean. So it’s just gonna have to survive on 4 tcase bolts because there’s no way I’m dropping it just to send the trans out to get a thread repaired. I don’t have a drill big enough to fit the drill bit required to helicoil it myself.
But whatever. It’ll be enough to drive the pig.
Making your own poly is pretty easy.. i made my own for my trans side until I got a better one from boostedfab.
As a matter of fact if you reach out to them they may do some solid bushings for subframe.
Hey man so I am back on this thing again. I just ordered my ATE from Volk and looking around at pour kits. Where did you get yours from for your trans mount? Just want to amek sure I am not overlooking obvious options, or that maybe my search terms aren't leading me in the right direction.
TIA
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted 2g WTB: 2G Eclipse GSX / Talon TSi AWD (1995-1999)
    Looking to buy a 1995-99 AWD Eclipse GSX or Talon TSi — running or project, rust-free bones...
    • Total Eclips3
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
