chrisman287
5+ Year Contributor
- 1,159
- 1,118
- Jul 19, 2021
New York
This is the side that goes on the ofhIt doesn't look small to me.
Did you already run this adapter and saw that is causing some flow or pressure issue? If you didn't, what's the reason to port before seeing the actual function? Like the same as porting OFH, when you actually see the real need to port, then should do it. Shouldn't port by just guessing or more than it needs. Once you port, you can't go back easily and wasting the parts in many cases.This is the side that goes on the ofh
Haven’t run it yet but you’re probably right. I’m just trying to avoid any possible problems.Did you already run this adapter and saw that is causing some flow or pressure issue? If you didn't, what's the reason to port before seeing the actual function? Like the same as porting OFH, when you actually see the real need to port, then should do it. Shouldn't port by just guessing or more than it needs. Once you port, you can't go back easily and wasting the parts in many cases.
Had a bunch of stereo components laying around, so I put together a system. Cost...$2
Got home from work and fiddled with the interior a little bit. Still looking for what's causing the moldy smell from sitting so many years.
Then felt bad and washed it. Might get some new headlights to make it look halfway decent.
Probably the carpet or headliner.Still looking for what's causing the moldy smell from sitting so many years.
Headliner was removed for reupholstery. It might be the carpet but I had it cleaned and hot water extracted, so im not sure.Probably the carpet or headliner.
Watch your silicone hoses over time.. on e85 i was getting moisture pulling through somehow and went back to regular rubberChanged all the rubber hoses from vacuum block to silicone instead. Now bov, wg, fpr, boost controller and map sensor have a nice tight fit.
Also cut down my intake pipe a couple of inches. The filter being so close to the fender wouldn’t allow me to install the headlight on that side.
The axle pops out of the intermediate.if you pull-out the front driver side c.v. axel and the input/intermediate shaft comes out with it what dose that mean? My c.v. axel to replace it looks like this
. Here is a video of the axel broke still in the car with car on ground. Was told the bracket is prolly broke also for the intermediate shaft
Another junkyard scoreYou must be logged in to view this image or video.You must be logged in to view this image or video.You must be logged in to view this image or video.
Say wha???!!! Congrats on that find...Another junkyard scoreYou must be logged in to view this image or video.You must be logged in to view this image or video.You must be logged in to view this image or video.
