What did you do to your DSM today?
Worked on mounting my fuse box again, got it all figured out and just need to bolt it up. After that I need to mount my LED glove box light since the OEM mount is broken. Then I can bolt the HVAC ducting up and the dash is ready to go back in. I also need to figure if I can to fix the hole in it or just leave it for now.
Here's what I did Yesterday.
Bad ass super 94 or 99?
When i get a bender i was gonna make a tubular rad and intercooler support and chop the old out like you, but until then. Oh well :(
"finished" up the controller. the microcontroller this time is a nano paired with a hc-05 bt module on an "adapter" board (adapter since the microcontroller board footprint is based off an Uno).
[ame=http://www.youtube.com/watch?v=TQprkIQS7tI]YouTube[/ame]
I honestly don't know why I'm still doing this thing.. probably because, despite my job title, this is the only programming I've done in the past 6 months LOL
YouTube
Is the sequencer controlled by Wifi?
Great now I need to look into more neat things to add to my set up.
I finally have my chassis harness ready to be taped and loomed. Ran the last few wires this am and made my connector pin outs.
Bluetooth using an HC-05 module (with breakout board), connected to the hardware UART on the atmega328 (arduino nano chinese knockoff) via 3.3v TTL on RX (resistor based voltage divider - 100/200 ohm since theres another resistor on the bluetooth module pin further limiting current).
I wanted to do software based serial communication so that the hardware port was free to do text-based debugging output, but I found that with as complicated as the code can be, especially during sequences, the arduino couldn't keep up with even 9600 baud in software and it couldn't communicate reliably with the bt module. This ended up in garbage data "appearing" to be received. Took a while to realize that one LOL
Switching to hardware solved that instantly. Luckily the code is 95% complete so I don't have to worry about needing debug output, really. I'll wing it the rest of the way.
Got my heatsinks for the regulators today. 150x20x6mm for $6. Can't complain; just need to mark, drill, and cut them now.
That's awesome.
I must say you've inspired me to start back at my LED retro again. Turns out I lost my last revision of my drawings and I've spent the past few days drawing in AutoCAD again...sigh.
I've finally finished my ECU/Engine harness for my car. Chassis harness is done too but I haven't uploaded pictures.
Powdercoated Diff mount, and rear brake assemblies (Should of used flat black to hide pitting/JBWeld repairs)
Reassembled e-brakes (hopefully the correct way) :)
Its a bit ricey, but I've always liked the underglow look. Installed tonight.
TMZ hawtness!!!
[/URL]
[/URL]
  • Wanted OEM Front Mud Guards
    ISO 1GB Eagle Talon OEM Front Mud Guards
    • Cj Anderson
  • For sale 2g 2g auto speedo gear
    2g auto. 97-99 speedo gear. From a GST trans. 29 teeth. Price is shipped Message 702-741-6987
  • Wanted 4g63t Valve Cover
    Looking for an uncracked 4g63t valve cover
    • victim
  • For sale AUTO DSM 91-96 300M UPGRADED TRANSFER CASE
    One of my spares Beats having to ship and waiting 8 months. Can do asking price or $1340 w/ your...
    • The_Partout_Spot
  • Wanted 1g Looking to buy a 1G turbo AWD
    Looking to buy a manual 1G turbo AWD DSM — GSX, TSi AWD, or Laser RS Turbo AWD near the states...
    • Rtsr
