- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 16g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- -Ported FP HTA68
-NGR Type S BOV
-Home-Depot "Motorsports" MBC
-Rewired Walbro 255hp Fuel Pump
-FIC 1120cc Injectors
-Fuel Lab AFPR (Extreme PSI Kit)
-Fuel Lab Fuel Filter Kit
-2.5 inch Custom o2 Housing
-Tial 38mm MVS Wastegate
-2.5-3 inch downpipe with cat delete
-Ported 2g Exhaust Manifold
-3 inch N1 Style Cat-back
-VRSF FMIC Kit
-Prothane Motor Mounts
-Megan Racing Aluminum Radiator
-1gNT water Pipe
-Forward Facing OFH
-1g Throttle Body with 63mm Plate
- Mods-Engine
- -6 Bolt Block 2.0
- Arias 9.0:1 Forged Pistons
-Eagle H-Beam Rods
-New OEM Crank
-ARP Main Studs
-ACL Bearings
-Balance Shaft Delete
-Ported 1g Head
-Supertech Dual Spring Valve Train
-Kiggly HLA
-HKS 272 Cams
-MLS Headgasket
-ARP L19 Headstuds
-Ferrara Valves
-Topline Lifters
-HKS Adjustable Cam Gears
-Gates Timing Belt
- Mods-EMS & Logging
- -ECMLink V3
-Speed Density (Omni-4 Bar MAP & GM IAT)
-Prosport mechanical boost gauge
-Prosport electric oil pressure gauge
-AEM Uego wideband air fuel
-Glowshift 3 Pillar Gauge Pod
- Mods-Drivetrain
- -Solid shifter cable bushings
-Prothane Shifter Base Bushings
-Mishimoto Weighted Shift knob
-Megan Racing Short Shifter
-Competition Clutch Stage 4– Strip Series 1620 with ACT Unsprung Street Disc
-Fidanza Aluminum Flywheel
- Mods-Handling
- -KYB AGX Adjustable Shocks
-Progressive Lowering Springs 1.8" Drop
-Home-Depot Camber Kit in Rear
-EVO X GSR Rims 18x8 +38
-BFG Sport Comp 2 235/40 R18 Summer Compound
-3000gt VR4 4 Piston Brakes
-Caliper Stiffening Bolts
-03 Cobra Rotors
-Hawk HPS Brake Pads
-SS Braided Brake lines
- Parts Wishlist
- A reliable, working car.
