Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
You should show him the 700hp capable fp turbos for that price and ask if he can match the $ per hp
My water pipe still goes from the bottom of the t-stat housing to the water pump. I suppose you maybe confusing the 6-bolt water pipe with the 7-bolt? The lower radiator hose goes to the t-stat on a 7-bolt, the lower radiator hose goes to the water pipe on a 6-bolt if I remember correctly.
Or was it something else, guess I don't follow?![]()
Here's a good shot of what the 7-bolt t-stat housing looks like if that's what you're referring to Chris?
Thanks for the compliments but the engine bay is still a work in progress, still a few things I want to do before I'm happy with it. A complete body/engine harness is one of the projects I'm currently undertaking.Yes I completely forgot thats what the 7-bolt T-stat housings look like.
Either way, that bay is killer. And because you have those nice long runs of hose, they should be a lot easier to work with then the ones I have to use.
Planning to run any ducting?
Replacing radiator again.. Lol hopefully this one doesn't leak!
Put another radiator in this morning! Works awesome!
i explained this earlier, punctured my koyo with a t bolt clamp, replaced woth a 20$ oem rad which had a crack when i bought it that i didn't know about, got another oem rad from lurker on here and now everything is peachy, 3rd times a charm.180* CT's
Non stock thermostat?
Yep. I don't recommend getting the PnP plugs though, just solder the connector pigtails that come with them. Those PnP connectors have issues coming loose and making a poor connection, not something you want to happen going WOT...
Don't forget the resistor pack delete plug!![]()
You're going to love those 2150's btw, even on 91 my car idles like its got 450's in the fuel rail.
