2G What bolts go here
NHerron
2,776
65
Nov 5, 2011
Missoula, Montana
I have one question about two different things.
First picture-
Main harness plastic channel thing.
What bolts goes here (3 of them)
Second picture-
Fuel filter bracket.
What bolt goes here to clamp it down?
Third picture-
For your enjoyment to wonder what it is :)
Pictures would be great, or part numbers. I can't find said bolts in any diagram on Mitsubishi ASA (caps) parts program.
I will fix in the morning. I can't get the pics to load.
But it's just the fuel filter clamp bolt.
And there is a plastic harness bracket channel thing that bolts to the frame.
Look between the alternator and radiator next to frame and you'll see the main harness snaking out. Well where the harness comes out of is the said plastic bracket thing. If someone could take a pic of the bolt (or just the head of the bolt) that would be fantastic.
The bolts for the harness channel are M6 x 1.00, washer assembled. I'd expect the length is somewhere between 16 and 20, not positive.
The two bolts here are M8 x 1.25 x 14, also washer assembled.
19eclipse90
The fuel filter bolt I'm talking about is actually a 6mm. That picture doesn't show the other side where the clamp ends meet, cinched down with a 6mm bolt.
And the channel, do you know what part number?
The pictures are just absolutely refusing to post.
Ah, that one. Glad you got it figured out for the fuel filter. I don't think that one is available separately from the bracket from Mitsubishi. Any old M6 x 1 bolt of appropriate length will work.
Channel bolt PN MS240121.
Update-
I didn't realize that the fuel filter came with the bracket itself. Therefore the bolt also!
Which explains why it's not a listed P/N.
Pictures attached.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
