dustin_8907
- 83
- 0
- May 7, 2008
Ripley,
West_Virginia
Just wondering what is good out there. I have a mishimoto aluminum radiator if that would help on my coolant quest
Distilled water and Redline water wetter.
Would this be a good idea for low temperature this winter or should I add in some amsoil antifreeze 50/50 with distilled water and redline water wetter?
Just straight water but i had a coolant leak.
What antifreeze/ coolant are you using?
ethylene glycol is ethylene glycol
I used tap for a little while (about 1 year) and I had a lot of surface rust built up in my cylinder head, and a good deal of rust and calcium built up on my water pump-to-block area. Ever since then, I've only used distilled. I may, however, have a lot more iron and other minerals in my water source that others.
