What Fluids are you guys using?
dsmcoder
382
Oct 12, 2010
Havre, Montana
I have a 1991 Mitsubishi Eclipse GSX Auto and I would like some opinions on some fluids. I need to replace my transfer case fluid and my automatic transmission fluid. What do you guys recommend and I also see temps from -30 to 100 in Montana if that makes a difference.
So many options, now I'm thinking about running Oem for auto trans and redline for transfer case.
Engine
Royal Purple 5w-30 in the winter
Royal Purple 10w-30 in the summer
This stuff is amazing!!!
Tranny
Redline MTL/M90 Mix.
I prefer to use cheaper lubricants and change them more frequently...I recomend mobil and I. Use costal gearlube
Should I use an oem filter for my trans? I can't seem to find one, if anyone knows where I can get one that would be great. My trans is a W4A33
Royal purple is great, the price often sucks, but i use it all throughout my drivedrain, motor, tcase, tranny (5spd), rear diff. I've used Amsoil which is good stuff too and cheaper, but the difference i did notice between the 2 was enough for me to pay the extra for the better wear and protection, and my car runs and drives much smoother.
I found a transmission filter for a F4A33, does anyone know if the W4A33 uses the same filter.
I run Amsoil's Signature Series and their GL-4 gear lube in the transmission in my GST and I would recommend to anyone. If I ever get the motor rebuilt in my GS I'll make the switch in it as well. They really make some outstanding products :thumb:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
