What Fluids are you guys using?
dsmcoder
382
Oct 12, 2010
Havre, Montana
I have a 1991 Mitsubishi Eclipse GSX Auto and I would like some opinions on some fluids. I need to replace my transfer case fluid and my automatic transmission fluid. What do you guys recommend and I also see temps from -30 to 100 in Montana if that makes a difference.
I use Valvoline Atf + 4 full synthetic. Most guys on the Link forum recommend it and they are in the deep 10's.
For the rear end I'm going to be using redline heavyweight shockproof.
They sell that valvoline at walmart, just an Fyi :)
Waste of money for no real gain or performance what so ever.
Seriously, The best bang for your buck will be the Valvoline.
If you go with something other then Redline Heavyweight or lightweight.
Get 75-90w for the rear diff.
WHAT!!!!! Royal purple is great since ive stopped using mobil1 and gone to royal purple ive noticed it driving alot better and the lifters dont make as much of a noise! Valvolene is good but only if you get the good stuff that costs good money! I use to run valvo in my old skyline and it ate bearings and scored the linings like a fat kid with candy!! All jokes aside. Since royal purple in my engine and auto transmission ive felt a huge difference in responce to both parts and beleave it or not the atf fluid. hange has even made the car faster some how! But i do also beleave in unicorns haha jk
The only other oil brand i would use would be amsoil but the race quality stuff.
^^^^^^^ +1000
Check this link. It´s a comparative between oils. It´s in Spanish but watch the videos and Royal Purple wins by a landslide.
http://dpcmx.net/portal/index.php?topic=15019.msg162629;topicseen
They have a testing thing on royal purples website aswell. And i think its mobil1 and either valvolene duratech oil or castrol im not 100% sure.
I had not seen the video on its website. It really is a very good oil. Somewhat expensive but very good.
Do NOT use Syncroshift in your AUTO. Either OEM, or equivalent.
I ran both the OEM, Valvoline high mileage, and Valvoline Syn+ in my trans. No real difference for the street.
I added a bottle of Black Lubegard also.
Jacks transmission's lists what fluids for trans,transfer case,and rear diff. I would not use anything other then what they suggest.
Thats fine. But he has an Auto trans. Not a Manual......
So the trans will take ATF..... The t-case and rear diff will take gear oil as recommended.
If you are good on oil changes, it doesn't matter. I've never had an issue with my valvoline and I'm not about to drop 60$ for an oil change. If you are consistant with changing your fluids and making sure they are topped off, you shouldn't have any issues.
Everyone has their own opinions but not everyone can realistically afford royal purple for fluid changes. I was considering using it before I tried valvoline in my transsmission and went to ask around the Ecmlink forums, the majority of people use valvoline full synthetic these are guys well into the 10 second quarter mile times. I think I'll listen to them.
This would seem to be common sense to me. I simply answered the question about what I run. I don't own a slush box nor would I ever advise to run gear oil in an auto.
Then why the hell did you come in here and post??? :rolleyes:
As for fluids In my black car I run All RedLine fluids from Racing ATF for the trans to Heavyweight Shock proof for the trans.
In my White car which is a little more mild, I run the same HW shockproof for the T-Case and rear but use the cheaper Valvoline in the trans. Its a decent budget oil but when you make big boy power it just doesn't hold up the same...
I upgraded to a MASSIVE cooler so I am hoping it will help ad some life to this stuff. Its nice to pay only $5-6 a qt considering how much you need but it definitely holds no candle to how stout this redline ATF is.
On a side note I'd also recommend Amsoil. Its pricey but also a great fluid. John Deer is cheap for high performance but it is thick so be cautious. Street driving is sluggish but it will help tighten up a really loose TC for the street.
Motor oil on either car is a toss up. I run 20-50 and 10-40 defending on the time of the year and usually grab what ever is on sell. I change my oil so frequently that it honestly doesn't matter very much.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
