ECMlink Weird issue with oxygen sensor
Ethan_zdon
Nov 13, 2021
Isanti, Minnesota
1996 Mitsubishi Eclipse gst (16g turbo, ecm link, 750cc injectors, cai, 3 in. Exhaust)
So my car has been running rough, has a stumble at idle and lower rpm’s. So I went out and got a used lsu 4.2 and aem Wideband set up. Car ran the same with it in and was around 15:1 at idle. About 5 minutes into running the gave me 3 dashed lines and stopped reading, data log showed as 18:1. At the same time combined fuel trim shot to + 25 and the car ran great. Can anyone explane this and is it as simple as a bad sensor and needing to increase fuel in my tune?
I can't comment on the initial issue but your sensor likely died or lost connection leading to the fuel issue. Those sensors die fairly frequently so it wouldn't be a surprise. Always run a dedicated 12v power with fuse and relay. Never share wideband power with anything else.
What would the shared 12v and gnd cause. They should be paralleled so same voltage.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
