Resolved Verify CAS disk orientation 1g green top
Anfurnyy
Supporting Member
1,509
1,958
Jul 4, 2020
Rapid City, South Dakota
Title says it all pretty much.
I need help verify that I have the CAS disk installed the correct direction and not flipped backwards.
I pulled it apart to block off the big window in it for my Kiggly 12-1 tooth trigger and I was in a hurry and didn't pay attention to which direction it needed to be.
Here's how it's currently installed:
Kiggly picture shows the disk flipped the opposite way..
and other pictures of the disk I've found online are the same as mine But wanted to verify.
Solution
I'm spatially challenged at this time of night but based on all the pictures I have yours seems to be correct.
I can't visualize what the diagram in the DTM would look like if they showed it in the the actual direction of rotation (counter-clockwise) but note how the disks pictured have the little inner slot lagging the closest outer when moving CCW same as the DTM shows with a CW rotation.
Been a while since I opened one up but I would assume Kiggly's drawing is correct, also assuming you did this for a standalone ECU, it doesn't honestly matter, it's just used to reference which phase the motor is in.
If Kiggly's is right then mines backwards and could explain my my car has such a hard time starting. Doesn't generate an RPM Signal..
I'm using a link g4+ PNP but it's got a bunch of other BS attached to it.
From the 1G technical service manual:
Note the arrow showing direction of rotation. So, as shown in this diagram, you’d be viewing the disc from the driver side while it’s installed.
Solution
I did something like that a long time ago when a similar question was raised but never verified my impression. And last night I could hardly think my way through all the conflicting information.
I'm not sure what Kiggly's diagram is doing?
Looks like he cut and pasted from the DTM to show that the TDC slit needs to be masked off in this use case but didn't fix the issue with the DTM image.
Well just to round back on this, this was not the cause of my starting issue.
It was a matter of Falling vs Rising edge triggers. But this is a good post to have on file in the forums anyways.
Thanks fellas.
  • Wanted 2g WTB - 2G Cluster
    Looking for a donor 2G cluster for a project.
    • rwmagee90
  • For sale 1g 1g FWD 3speed design scattershield
    1g fwd shield
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $35 each. Message 702-741-6987.
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale Cts-v calipers+rotors+adapters
    1g/2g CTS-V calipers cobra 12.99” and ctsv adapters, $650 plus shipping&pp fees text me if you...
    • Fully built dsm
