ECMlink Turned the boost UP.......e85 i love you
When you retorqued dis you loosen first then re tighten? Im running a hks gasket. So mich thicker and heavier then what im used to seeing.
No I didnt ........Im getting close to 40 psi, im considering doing a oring setup.......This is part of the game I guess, I could just keep the boost below 30psi with a composite but what fun is that?
I wouldnt do that either. Id re check the leak down and make sure the gasket is bad. If so remove head and check block/head for flatness. If good try the hks gasket. Its supposed to be the bees knees haha
Why would you keep boost under 30psi on a composite?
The 4g63 is a strange motor, I never had as many headgasket issues on any of the honda motors i built. How many of the guys on this website leakdown test their engines often? Ive been so careful to check and double check every measurement. I bet you there are guys driving around and dont even realize their leaking. I think running the composite is excepting defeat. Nothing against guys who choose to run them......but if you want to make serious power thats gunna last you need to oring the block.After running high boost through two composites they scare me, when they fail they fail. I just spoke to my machinist, im getting the block oringed
Ok so its official , im dropping off the block to be surfaced and oringed.....no more bullshit
Is this going to be on your new block or current one?
Before u tear her apart give us a clean pull from 2500-redline. Nothing wreckless if you do it on a highway on ramp. You'll only be mid 90 mph.
Its strange our motors can handle so much power but are very sensitive. Ive seen honda guys blow a headgasket (mls) pop the head off and just throw a new one on. Not resurface anything. Go on the dyno and make 800whp and rev to 10k. Not push a drop of coolant too. If i only didnt work for honda id build one. Plus swap a 4wd drivetrain in like clm motorsports did.
:hellyeah:
This is gunna be the new block, standard bore with better rods. I have some Manley turbo tuff rods in my closet with some wiseco hd Pistons. I chose to go with the eagles with this engine as this was my first build. I meant fast for public roads around were I live. I'm going to take her out on the highway and rip it one last time before I pull her apart. Who cares right?:hellyeah:
This is what im going to do, im gunna put the hks headgasket on the motor and see if it fixes the issue, while im doing this ill have the block at the machine shop. Changing a headgasket isnt a big deal....
After feeling what 37psi feels like.......I'm officially a boost whore.This is a testament to the engineers at Mitsubishi, the fact that the transmission and driveline can handle all of that extra torque is incredible. I'm going to be a master technician after I'm done with all this bologna...
They handle it for a limited time.
You are officially a "BOOST JUNKIE" now!!! :applause:
I went out last night and got my "FIX". :)
You should talk to Raif Fejzo from RRT. He's the man there in Canton CT. He o- rings all his motors
http://rrtmotorsports.com/team-view/raif-fejzo/
My first engine went to rrt, I used his guy to do the machine work for me. I was going to have home assemble it but he's alil over my pay grade so I built it myself. Raif has been extremely helpful throughout this process, he's a good guy. Hopefully he can share some of his oring wisdom with me so I can solve this headgasket issue and I can turn the boost up.....
