1G Turn signals won't work
BoostedTT91
285
7
Aug 2, 2004
Elysburg, Pennsylvania
Ok everyone looking for some other thoughts here. I was driving my 91 talon the other day and all of sudden my turn signals stopped working. I'm having trouble finding the cause here. All my lights work normally and hazards work normally.
I have checked all the bulbs and none are blown, checked the fuse and it's fine. Tried switching hazard switchs and tried a different turn signal switch assembly and still will not work. Anybody have any other ideas I could try
Man this is tough. Clearly you have ground/s or the hazard flashing part wouldn't work.
There are 3 fuses that work this circuit, my $$ is one of them is bad.
There is the Hazard fuse in the black box under the hood. This has to be good if the flashers are good.
Inside the car in the fuse box by your clutch foot there are two fuses 17 and 12, check and double check, remember to always replace a fuse and not just look at it or test that both sides of the fuse to see they are hot. And just because the fuse is good doesn't mean it is making good connection in the fuse block itself. After all these years I have seen people jam all kinds of things in the fuse block for acc items.
If those all check out then by default you have a bad connection or broken wire somewhere in the circuit between your switch and the hazard switch and you'll need to start OHMing out each wire checking for continuity.
Which fuses are you referring to inside the car? Only one I know of is 5 which is the turn signal fuse
Checked and double checked all the fuses and they are all good. Guess gonna through absolutely everything one by one
