2G Turbo convert--> oil pressure gone
patman
5+ Year Contributor
107
62
Oct 19, 2017
Budapest, Europe
Hi
I've converted my N/A 4g63 to a T25 turbo build. Basically what I did is
T25 (OEM, freshly rebuilt)
- Stock GST exhaust housing (OEM)
- Dejon intake pipe
- OEM intercooler
- Forge style Epman BOV
- Depo racing mechanical boost gauge
- Walbro 190 LPh Fuel pump
- Ebay open dump O2 housing
- Custom 2,5' downpipe
- OEM GST ECU
- OEM black top GST injectors (450 cc, with resistor packof course)
The GST ecu and the fuel pump is not in yet, but I started the car and it has seriously low oil pressure, so low it creates black smoke puffs, and dies on me. I've changed the oil pressure switch to a new one from a Mitsubishi Galant, guessing they are mostly the same. The problem occurred after giving it a bit of a push on the road. Can I solve the problem by changing the ecu? I don't see where they are related in this problem
yeah, I hope so thats the problem. The only problem is the new ecu doesn't send signal to the fuel pump, do you think there is a guide somewhere here how to hook it up with the fuel pump?
I can't tell you excatly, I don't have an oil pressure meter only the OEM one, but the oem goes reaches halfway to the lower line, and the oil warning is flashing all the time.
I'll put try putting in the GST ecu, but I don't see how that can solve the problem
Can the problem be that I bought aftermarket Mambatek Oil feed line for the turbo? It has a 1,8mm reduction right where it connects to the turbo.
https://www.ebay.com/itm/273362873761
My guess is you don't have an oil pressure problem. The car is running like shit because you changed injectors and not the ecu and the car is almost dying and low rpm is causing the oil pressure to get low.
I spoke with Patman and upon seeing where he tapped into for his T25 feed, I may have a clue to what's going on. I'll write my theory here maybe someone can chip in and say if it's a possibility or not?
Basically he currently has a T fitting in between the oil filter housing (N/A variant) and the oil pressure switch. So oil goes to the pressure switch, but also splits off to feed the T25 (with the little restrictor). Now, as far as I understand things, pressure sensors such as this oil pressure switch are designed to act as a dead end and receive certain amounts of oil pressure. Oil simply makes its way to it and stops there, pushing against it and making the switch sense X amount of oil pressure (which is then sent as a signal to the ecu). In Patman's case, right before the oil pressure switch, there is another line that diverts most of the oil towards the turbo. Thus, it stops being an actual dead end, so the certain amounts of oil pressure that the switch is designed to receive is now disrupted. It is no longer X amount of pressure per any given RPM, but rather X - Y (Y being the amount diverted to the T25 feed).
Based on this, I believe he should install the T25 feed line in the tapped oil hole to the right of the oil pressure switch. On a turbo oil filter housing, that is already installed as the factory restricted T25 feed. But on both N/A and turbo housings, there is an additional 3/8" BSPT tapered tap located on the same side of the housing. I believe he can remove that plug and install his aftermarket T25 feed line into there. This way the oil pressure switch will remain as a true 'dead end' and sense the correct amounts of oil pressure (and thus not put the ecu into limp mode), and he will also have a stand-alone oil source for the turbo.
The only last worry I have, is if this 3/8" tap actually plugs high pressure oil, or is just an empty cavity left over from manufacturing reasons. Also, here's an illustration of which plugs/taps I'm talking about, and the differences in turbo and N/A oil filter housings. The yellow circles indicate the stock oil pressure switches, the red circles show the stock T25 feed line on turbo housing, and the plug on the N/A housing.
