bigbrdf250
- 59
- 0
- Dec 9, 2011
SugarLand,
Texas
my car starts but is not driveable yet,, still working on things, but when i installed a t fitting right before the turbo to meter oil pressure i read 14psi at idle give or take depends on idle, and with my 2 step holding at 4800rpms it reads about 50psi no more though.
my feed is from the ofh -4an which looks to have a restrictor in it?? when measuring off a t from the ofh at the sender port my readings are way high, at around 4800rpms im reading around 80+pressure. that leads me to beleive i have some type of restrictor??
my main question is i cannot go wide open throttle cause of the set up so im bouncing at around 4800rpms and reading 50psi of pressure, is this ok and when at wide open throttle on the street will it keep this pressure?? its not smoking and have one of those crap -10an ss lines from extreme.
