Ludachris
Founder & Zookeeper
- 8,879
- 4,726
- Nov 12, 2001
Newcastle,
California
I know it's been talked about before, and we've had some small vendors who tried to make them available (and never did). But why not use this thread to start spec'ing out a front sub-frame/k-member for the 1g?
I'd say it would be best to make something that bolts right in and uses all the stock mounting points so that all the stock suspension pieces can be used if so desired. If there are provisions to change the suspension mounting points, like moving them up for lowered cars, that would be great, so long as the stock points can still be used along with factory control arms.
I'm thinking we'd want to focus on steering rack provisions that will make both drag racers and road racers happy. And maybe there should be a couple options that make the sub frame stronger for road racing (side loads), and lighter for drag racing (which doesn't see side loads). The road racing version might have a few extra braces.
Take a look at the aftermarket k-members designed for the Mustang here:
BMR Fabrication Products
You'll notice there are a few options to choose from that changes the design.
Thoughts?
Thoughts?
