Please Support Rix Racing
Street Build 1998 GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Build Type
  1. Street
FP cerakoted race manifold, HX35W w/ cerakoted BEP housing, JMFab external wastegate o2 housing, tial 38mm wastegate, JMFab drag intake manifold, 3" full exhaust, Fluidampr harmonic balancer, custom 4" intake, fmic.
Fuel system: -6an pro-classic feed and return, walbro 450 fuel pump, fuelab filter, FIC fuel rail, PTE 1200cc injectors, aeromotive fpr.
Mods-Engine
6 Bolt Swapped!
Head: GSC beehive springs/titanium retainers, gsc zero tick lifters, gsc viton seals, bronze guides, standard ss valves, kelford 280's, fidanza cam gears, kiggly hla, map h11 headstuds, oem mls headgasket, slight port and polish.
Shortblock: Custom AMS spec 9.5:1 JE pistons, groden rods, acl race main and rod bearings, kiggly girdle, arp main studs, GSC race BSE.
Mods-EMS & Logging
ECMLink V3 full, speed density, AEM dual nozzle meth kit.
Mods-Drivetrain
Quartermaster rally twin disc clutch, boomba rear differential girdle, magnus transfer case girdle. Torque solutions: driveshaft carrier, shifter cable, and subframe bushings. Avid motor mounts.
EVO 9 Brembo calipers (f&r), new drilled & slotted rotors, hawk hp pads, JNZ conversion SS brake lines, kyb agx all around, FD wheels with azenis rt615 tires.
Background
Just a fun street car!
  • Like
Reactions: greekgodchaos
KazooGS-T
Rating
5.00 star(s) 1 ratings
More in 2G DSM
Share this Vehicle
