Transfer case, After-market and OEM bearing part numbers.
mitsubishikid
1,167
266
Jun 8, 2009
Turlock, California
I happen to have a blown 22 spline transfer case... the previous owner of my Colt gave it to me, so I decided to rebuild it as a backup unit.
After tearing into it I discovered that the Tcase was in better shape then I expected apparently the bearings are wasted, but the housing and gears look to be still use-able
as I tore it down I started to see bearing part numbers on the cups and bearings, so I decided to write them all down, and share them with members, just in case you want to order everything in advance to do the job.
screen capture
Above is a Mitsu CAPS image I'll use for reference.
[Number in picture above to reference location] [part number you might be able to cross at auto parts stores] [OEM #]
30461------------------------------------------------- # on bearing[LM67048]# on bearing cup [LM67010][OEM # MD717511]
30453-------------------------------------------------[32010XJ] [OEM # MD723636]
30307-------------------------------------------------[32009J] [OEM # MD718322]
30454-------------------------------------------------[32008XST] [OEM # MR967457 or MD718323]
You might be able to use these numbers to get after-market bearings from Koyo, national, etc.
[I would recommend you try and avoid any cheep china made ones if at all possible]
Front oil seal on T case part numbers [Duralast # 1981] [SKF 11592] [TIMKEN 223014] OEM # MD723202 or MD703735
Rear oil seal, to drive shaft, part numbers [NOK AH1895E], [SKF 12736], Oem # MD701430 or MD701782
I got all the after market equivalent of these, unfortunately some National bearings are made in China[what isn't these days ], and it's hit or miss if you get ones made in, Japan, Germany, USA, Israel, etc.
I went to AutoZone and crossed the part numbers, these should interchange with most other auto parts stores.
CAPS Image number. AutoZone cross reference numbers/ Brand/part numbers
30461------------------------------------ National [A-6] Duralast [SET6]
30453------------------------------------ Duralast [32010X]
30307------------------------------------ Duralast [32009XM]
30454------------------------------------ Duralast [32008XM]
Front oil seal,on T case ---------------- Duralast [1981]
Rear oil seal, to drive shaft------------ Duralast [223240] or [710317] I'm gonna find out which works soon enough.
Hope this helps other members out.
_________________
Abe
Bringing up the dead but it's legit because there's other good info in here.
Has it been verified that 223240 is a fitting match for the tcase output seal in 1g/2g?
The one I have in my case is still good but I've got two 223240s in hand and now wondering if I should keep them as replacements.
I know, I could measure inside bore and outside diameter of the shaft, but I'm trying not to destroy the seal that's in there right now and avoid disassembly.
I also know that the Mitsu OEM parts are still available and cheap at <$10/ea + ship, I just had two and who knows.. maybe some day they will disappear as well.
I'll just try tor remember to add one to a US order when I do the next, and then I can measure if nobody knows.
