2G 97 T-case Bearing Part Numbers
DSMxTSi
84
24
Jan 26, 2003
Orlando, Florida
I've been hunting down t-case bearings for my manual trans 1997 Talon, but am having a hard time. I found the part numbers in the attached pics at mitsubishipartswarehouse.com but three of the four are listed for Automatic cars. Are they the same for manual cars? The site has no other listings for t-case bearings. I tried calling them but since Talons are not Mitsubishi they couldn't verify anything via VIN number. :rolleyes:
Yes, they are the same between Manual and Auto. And it doesn't matter if it's for Talon or Eclipse. You can verify and order it with Tim @twicks69 .
Inner Drive Gear (Facing Trans) Roller Bearing MD717511
Outer Drive Gear (Side Cover) Roller Bearing MR967457
Inner Driven Gear (Facing Front Section) Roller Bearing MD718322
Outer Driven Gear (Facing Tail Housing) Roller Bearing 2950A001
Thanks guys! You are life savers. DSM t-cases are hard to pinpoint the exact info. Maybe this thread can be put into the Drivetrain References section for others to find easier.
Tim, how do I order from you? Do you recommend anything else, shims? My mechanic may already have shims, but am awaiting his response.
Just email me at [email protected]
All the shims are sold as individual parts, and they aren't cheap, I doubt your mechanic has them unless he regularly builds DSM tcases and has a stockpile.
