1998 Mitsubishi Eclipse GSX
- Clean title
- Automatic
- All-wheel drive
- No rust
- 135,xxx miles on chassis
Exterior is 6 out of 10
Interior is 8.5 out of 10
Engine:
- 2.4L G4CS (Similar to the 4G63T, but larger displacement)
- GSC S2 cams
- Wiseco pistons
- Eagle rods
- GSC Stage 2 beehive springs
- GSC race balance shaft
- ARP and King hardware
Drivetrain:
- Borg Warner/AGP 7670 Divided T3
- JMF Street intake manifold
- Morrison Fab Divided T3 tubular exhaust manifold w/ Tial MVR 44mm
- Custom downpipe w/ Vibrant Stealth street muffler
- MCR billet valve cover
- Velocity Element R35 GTR COP- PTE BOV
- ETS super short route FMIC w/welded piping
- S90 TB
Electronics:
- Evo8 ECU w/ Link G4x
- Forced Four 100.1 Smart shift box and hand-held display/shifter buttons (Two tunes normal and sport)
- Shift kit
- Speed Density
- Electronic boost control solenoid
- Flex fuel tune (91oct to pump E85)
Fuel:
- Walbro 535 Hellcat pump
- JMF fuel rail
- FIC 2150 injectors
- Fuelab regulator
- -8an feed/-6an return E85 safe lines
Transmission:
- Cooler in the right bumper cutout
Suspension:
- G2 street coilovers
Wheels/tires/brakes:
- Wedsport SA-70 17x9 +35 powdercoated Kingsport Gray
- Falken Azenis RT615k+ in 245/40/17
- Willwood 4-piston calipers
- Front = Willwood blanks
- Rear = drilled/slotted
Interior:
- Evo 9 seats w/ Wedge brackets
- 1999 silver gauge cluster
- AEM temperature gauge (currently monitoring coolant)
- Innovate ECB-1 advanced complete gauge
- "Eclipse" floormats- 20% tint sides and rear
- Pioneer headunit
- Fire extinguisher by front passenger feet
Misc:
- Boosted Fabrication engine/trans/roll stop mounts
- Vibrant catch can/lines/fittings
- Mishimoto radiator
- Single SPAL fan
- Mishimoto coolant reservoir
- Jay Racing alternator relocation kit
- Factory non-ABS
- Billet brake fluid reservoir bracket
- Removed power steering, AC, cruise control, rear window wiper, antenna, and Idle Air Control (IAC).
Included parts:
- Power steering and AC
- 3rd brake light
- Factory antenna
- Original gauge cluster
- Misc. parts
Interior Cons:
- Rear section of the sunroof shade cover is loose (See picture)
- Very small crack on passenger door vent surround
Exterior Cons:
- The hood and driver door have been keyed
- Driver's side front fender has power steering or brake fluid spray that affected the clearcoat/paint
- Lower rockers have clearcoat fade
- Some coolant weeps under WOT
- Minor rock chips/dings/scratches expected for being a 28 year old vehicle
**Full-build list and dyno sheet will be provided to buyer.
I can include aftermarket parts for an additional cost:
- Kiggly Racing F4A33/W4A33 5-Friction Front Clutch Pack
- Jeff Bush billet input shaft
- IAC block-off plate with sensor
- Clean title
- Automatic
- All-wheel drive
- No rust
Engine:
- GSC S2 cams
- Wiseco pistons
- Eagle rods
Drivetrain:
- S90 TB
Electronics:
- Shift kit
- Speed Density
Fuel:
- JMF fuel rail
- Fuelab regulator
Transmission:
Suspension:
Interior:
- Pioneer headunit
Misc:
- Single SPAL fan
- Factory non-ABS
Included parts:
- 3rd brake light
- Factory antenna
- Misc. parts
Interior Cons:
Exterior Cons:
