1996 Talon TSI AWD $10,500
- 90,421 miles ( will go up a little )
- clean title in hand
- located in 08096 NJ
- NO TRADES
- 5 Spd Manual Trans, LSD Rear
Listing this 96 Talon TSI AWD that I’ve put a good amount of maintenance work into over the last year. This is a safe and good driving car that does not need to be towed. Two things that I would address on the car is the fuel gauge does not work and the paint could use a good buff and cut. This car has been painted at some point and shows really well but there is little imperfections that need to be buffed out and I have no skill in that area.
It is a relatively stock 2G with the mods being a full Apexi exhaust, K&N drop in filter, and aftermarket radio. Below I have listed some of the maintenance work that I did to the car in the last 3,000 miles
OEM Timing belt
OEM Tensioner
OEM Balance Shaft Belt
New Water Pump
New Valve Seals
New Valve Cover Gasket
NGK Plugs & Wires
Injectors Cleaned & New Orings
New Throttle Body Gaskets
New Battery
New Tires
New Exedy OE Replacement Clutch
Shifter Cable Bushings
All Fluids Changed
It’s getting pretty hard to put complete reliable running and driving cars back into our community but it has been absolutely worth it watching the local scene grow as well as the car count at The Shootout !
- NO TRADES
OEM Timing belt
OEM Tensioner
New Water Pump
New Valve Seals
NGK Plugs & Wires
New Battery
New Tires
All Fluids Changed
