AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
My goal is to able to turn on the d/s ac cooling fan using the factory setting (blower fan switched on with ac button pushed in) while being able to control the blower motor (on or off). If I unplug the connector to the blower motor, it works how I plan to use it.
Can I use this switch on the black wire to the blower motor? Basically a toggle switch for the ground side to the blower.
weideer 10PCS ON/Off Switch 12V Rocker Toggle Switch SPST Mini 20mm 6A/250V 10A/125V AC Circle 12 Volt Switch with Wires for Car RV Marine Boat KCD1-5-101-ON Off-X https://a.co/d/4ZzTHm0
