2G Cooling fans bypass to toggle switch
4yoto24
71
Jun 11, 2009
Bakersfield, California
Hello, I have searched several threads and dont seem to obtain the answer that im looking for. I will be performing the cooling fan bypass from Vfaq, however I have 2 questions, where do the 2 wires connect to the toggle switch (3prong) and does anything need to be grounded. I dont care much about the lightened switch, moreover would that mean i can use a 2prong switch? Someone Vfaq was not to clear on these areas help me. I live in Bakersfield Ca where evreyday we are at over 100 degress. . 2G gst by the way.
Just use a 2 wire toggle switch or if you want to run the fans always on high, it only takes one small jumper wire between the relay. That's how I had mine run before I got ecmlink. Let me know if you need anymore help bro!
Thanks bro. I went acccording to vfaq and after I finished the wiring I was only able to get one fan to turn on (radiator fan) with the toggle switch. My wiring looks identical to vfaqs diagram. I wonder what I did wrong. Ill post pics in a bit.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
