2G To replace just wheel bearing or whole hub assembly?
Hjelle88
56
Mar 23, 2012
Cloquet, Minnesota
I'm going to be replacing my front drivers wheel bearing (and probably the passengers side as well due to "one goes, the others sure to follow). My question as stated by the title is, do I replace just the wheel bearing it's self, or would it be better to replace the whole hub assembly?
It's on a 95 GST.
When I ordered mine from JNZ tuning, it was a complete hub assembly, it had the bearing pressed in and ready to go. It comes with new wheel studs and all. You just take the old hub assembly out of the knuckle and bolt the new assembly in.
Just get the complete hub assembly and some anti-sieze to apply liberally. They are cheap enough to replace the whole assemblies you don't need to bother with it.
Chris
So I got a question!!! At a local junk yard there's a 95 TSi AWD 5spd :hellyeah::rocks::D everything looks great(extra greasy but idc no rust LOL) I bought the 2piston calipers front subframe rear subframe transmission diff transfer case drive shafts all for $200.00 ROFL. But the car was ABS my spyder isn't :banghead::banghead::banghead: so I didn't buy the (2)rear knuckles or (2) rear hubs was that a bad move???
