2G Rear Hub or bearing assembly?
unlikely hero
273
Feb 2, 2004
Atwater, California
My rear driver side wheel hub is bad, I mean screeching bad. I'm trying to order what I need and I have the option between just the bearing assembly or the whole hub assembly. The hub is over twice as much and I'm asking can I just order the bearing assembly? Will I need to get it pressed in or what? Also anyone have a recommendation where I could get these at a lower price. Its like 90 for the bearing assembly and 240 for the hub. Thanks
=Jason-
=Jason-
Well first off, if this is an AWD, GOOD LUCK! This is not an easy job. I would recommend getting the hub assembly. I had to replace mine and it was hard enough just getting the hub off. What made this hard for me is getting the CV shaft out. And after i got that out, i ended up having to get a CV axle shaft and that was next to impossable to get a rear CV axle shaft for a 95 awd talon with a locking differential. I had to get a used one and a used one cost $125. Also i dont know where you are getting your parts but i got the hub assembly from advanced auto for $130. What was weird is it cost like $200 everywhere else, even from a different advanced auto from a different city. Maybe those guys just liked me and gave me a deal, I don't know...
GOOD LUCK...
You CAN just replace the bearing/race assembly if it didn't eat into the hub. I had to do that once on my 2g GST and it wasn't any fun. Just to be safe I would replace the whole hub though that way you don't buy the bearing and need the hub.
I just did mine about 2.5 weeks ago. i changed just the bearing assembly part. All you need is the right tools. I had to buy the right one after I pulled the bearing assembly off the rest of the hub one of the bearing races stayed on the hub. All you need is a puller the one that looks like 2 u's clamped together and pull it off. But that is the easy part getting the whole hub off was a pain. But it is definately doable.. But truthfully if I were to do the other side I would get the whole hub.. Hope that helps.. TTY
unlikely hero said:
LOL Yea finnally getting time to work on it now. First the hubs, then the engine, tranny, then the rust LOL.
=J-
i was thinkin about ya not that long ago, wondering how it was comming.
Apparently its not that far along :D
i see your wingless now -
thats the only thing that made me think hmm maybe it isnt the talon i sold.
g/l dood :) im thinkin you will need new hubs+axles.
cant you just swap the hub+axels+rear end from the other AWD u have ?
