TSIfreek
- 1,674
- 18
- Dec 14, 2003
cary,
Illinois
I personally would go with ID 2200s on E . I have no problem running them on pump gas or E85. I'm set up with flex fuel sensor and even Street driving it's like it's on stock injectors. If u dont plan on running e85 you can get away with much smaller injectors.
I don't need 2200s but gives me room to grow and I have no worries about running them ragged. I really do like what ID is doing in the injector market personally I think their the best out there.
. It seems I accidentally started with the ideal cam gear settings. I'm going to hook up the upstream injection and get that working so the tune makes more sense, and see if I can't find that last two tenths.
There is about 35 thou runout, lug pattern off centerline. Doesn't make a lot of sense though, I've obviously dynoed the car on these axles before. But the last time I tried at the old shop it was the same dismal failure. I can't imagine how that would have changed though, or otherwise how it worked the first couple times.
