97egl
- 878
- 566
- Feb 6, 2014
Brownsburg,
Indiana
Is there any noticeable difference in spool times between the 14b and T25. Looked in some old forums and all I found was people saying the t25 sucks compared to the 14b and runs out of steam around 6000 rpm but couldn't find any real info on difference in spool times. Also if you know of anything that can be done but look factory to decrease spool times that would be helpful.
If you want the full story of why I need to know this keep reading.
Going to be taking one of my cars to a very small 1/5 mile speedway for a 30 minute enduro race. The track is small and slow, running in 2nd gear I am only going to be doing about 3000 rpm coming out of the corners and maybe 5500 at the most going into them. I know the 14b already spools quite quickly compared to larger turbos but on a 1/5 mile track there is only a couple seconds of being in the gas before letting off for the next corner so I want to build boost as quickly as possible. Usually on larger tracks I am exiting corners at 4000-4500 rpm and it still takes a second for the boost to build so with lower rpms I am thinking its going to take the whole straight away to build full boost.
I am aware that I can get in the gas while still in the brakes on corner exit to spool the turbo a little but in the past when I have done this on larger tracks the brakes get so hot the fluid starts boiling and they fade out. I am running DOT 5.1 to try and combat that but all that does is make them go for longer before fading but they still fade out, so I only use that technique when I am trying to get around a difficult competitor.
Thanks guys
Thanks guys
