14b turbo spool
clizz3
218
Sep 25, 2011
franklin, Indiana
I bought a 91 gst about 6 months ago. Had bent valves. Rebuilt it to stock form. Noticed orginal 14b had major shaft play and got lucky and another at a local junkyard. Now that I've been driving the car I can't exact hear it spool. Is this an issue? Car feels like it gains boost. According to both stock and aftermarket boost gauge its sitting between 7-10 psi. Is me not hearing it spool a problem?
If the car has the stock intake system than it does hold a lot of the spool sound within. When I bought my 2g GST the entire car was completely stock and unless I had the windows down and was trying to hear the turbo, I couldn't hear anything.
Is the intake filter stock or does it have a cone style filter? As long as your aftermarket gauge is hooked up properly and you get boost when you should, I wouldn't worry about it. Take off your intake filter and take it for a quick rip, bet you will hear it then :sneaky:
My old 14b was quiet as well. Much quieter than my 16g even with hard pipes, cone filter on and injen intake. About the only time I heard it was when I was running 17lbs boost. Even then pretty quiet.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
