soft pedal after clutch master cylinder
KingJamesEli
Jan 15, 2015
tacoma, Washington
Basically I've been gravity bleeding my clutch master and slave for like 2 days and still soft pedal! Seriously about to beat the hell out my car. Help please! !!!!
A little late but if you haven't already figured it out, go and get you a bleeder cup for under 10 bucks:
http://www.sears.com/lisle-brake-bleeder/p-00947746000P
Basically, hook the line up to the slightly open bleeder, pump making sure the reservoir don't go empty and continue to do so till you no longer see air bubbles in the line connected to the bleeder. Great tool when you're on your own and don't wanna fork out $60+ for the vacuum bleeder.
That means that your line still have air inside, get a helper and bleed it correctly, and at the end leave the clutch pressed, screw slighty open and pour some more fluid to make the flush effect then quickly close it. Works for me all the time.
So confused. Got it all back together. Shimmed the new pivot ball and installed new fork. And it won't go into gear
