slim radiator fans
JeanDSM
405
Jun 23, 2004
Yabucoa, Puerto, Puerto Rico
Next feww weeks im goingt to install a turbonetics manifold and a 60-1 turbo with .70A/R compressor housing and all suporting mods. My question is will i need slim radiator fans or will it fit with the stock ones. If i need to change them where can i found cheap ones cus i already spend all the money on the turbo system
I have 2 aditional questions...
What cfm are required as minimum and can i install them between the radiator and FMIC or is it recomended between radiator and turbo? I want it to look as clean as possible
I would think you would be running a FMIC? If so, you should have already picked up some slim fans because you would most likely need a new radiator to compensate for the lost airflow from your FMIC blocking it. But I have seen some on MACHV.com for like 20 dollars I think. I'd say, save your money and do it right. So the answer to your question, I think the stock ones will not fit. :talon:
