trogador2005
- 133
- 59
- Mar 18, 2013
Fort Wayne,
Indiana
This is a shootout scramble ongoing troubleshoot. Would love some more input to try and speed this process up!
Here's what we've got:
2g Spyder GS. AWD and turbo engine swap from a 95 talon tsi
We have the 95 ECU running link v3 on SD
Omni 4 bar
Gm iat
Innovate wideband
Stock O2 for closed loop
Fic 1000 high impedance
Walbro 190
Stock fpr
T28
Delta regrind cams
We're actually using a 1g cas wired in like a 6 bolt in a 2g. (It was cause adjustable cam gears were used and didn't have the spot for the trigger plate since it's a 95 engine)
We used the 4g64 harness and added knock and changed how the fuel pump is wired (different for GS spiders) anyway.
The problem: never getting a CEL
The car was running perfectly for a couple months . Autocross events, wot, ide, cruise, no problems at all. then all of the sudden while sitting in traffic the car would bog and go lean, feels like fuel dropping out and back and out and back, it'll snap out of it for a second and go right back and die. Then it won't restart. When it goes lean the car fully fuel cuts, like the old hitting the brick wall. But it's not in boost, it's 5mph in a parking lot or 30mph on the street. Let it sit for a while and it'll be fine again for a random amount of time it seems and then happen all over again.
Nothing changed in the tune, as far as link goes, it's not calling for any fuel changes. IAC is behaving normally, O2 sensor is functional. Map and iat are reading normal.
What we've tried:
Replacing the fuel pump (ran fine til it didn't cause it sat while we swapped the pump)
Testing injectors (applying 12v to the individual injectors to hear them energize)
Swapping out for (no change)
Lock in open loop (no change)
Swapping ECUs (no change)
What we're going to try next:
Testing the wiring to the injectors
Testing wiring to the CAS
Thanks for helping!
Omni 4 bar
Gm iat
Innovate wideband
Walbro 190
Stock fpr
T28
Delta regrind cams
What we've tried:
Thanks for helping!
