Removing ABS
FeaR-GSX
60
Aug 10, 2011
Thompsons Stn., Tennessee
Ive looked online but haven't found a definitive answer. I want to remove the ABS on my car, im going to get an OEM non-ABS proportioning valve, with that installed can i can simply remove everything associated with ABS, (lines running to box near driver headlight, abs ecu under glovebox, etc.)? Also how do I turn the ABS light off after doing this?
Need to re-route the lines since they no longer need to go to the front corner of the car. I plan to reuse those long lines (Cut/shorten/rebend/new ends..etc..)
I believe you just pull the ABS bulb to turn it off. :)
