JonathanNL
- 58
- 6
- Aug 24, 2006
Netherlands,
Europe
At this point though, I am officially calling the AWD rear subframe mounting panel "DONE"!
Looks good, but... where's the FWD love?
Looks good, but... where's the FWD love?![]()
Answer's don't have to be super long, just enough to get the point across. Be aware that you may require several tools/bolts/ect for installation. More on that via PM.
) It will require the cutting the panel we've talked about to accomodate your stock routed exhaust (if you chose this), mounting holes drilled on panel and potentially your bumper, hardware to mount the diffuser to the vehicle, and hardware to mount the strakes. I will (and if needed, hopefully this thread) provide feedback to help assist through any process to get the diffuser installed.
Try to get the info to me asap though to be considered, and I'll do my best to keep the time frame goals met.One of the main pain in the ass things about panels like this is shipping, so take that into account. It won't be cheap, because of the odd shape and size. I made some carbon fiber fenders and they wound up running $28 a piece even though they weighed less than a large book. I take it as a given, but some people look at the price and are already stretched thin, then get hit with the shipping and throw a fit. My practice is to just factor it into the final price and never charge shipping. That prevents the "added expense" feeling some people get when they look at the price before shipping.
I found to this thread via a search for unrelated info, but wanted to clear up a point here. I recently contracted with a well-known aerodynamicist to evaluate my race car, and one of the points he made was how a front splitter produces downforce. This is best shown in the below computational fluid dynamics-generated image of the front end of a car with a modest splitter extending forward of the front bumper. The area of low pressure is the blue area pointed to by the red arrow (see the scale on the left of the image for see what the pressures are in any particular area represented in the image).I just took fluid mechanics last semester... Isn't slower moving air at higher pressure, not lower? Isn't that how a front splitter works? I thought that caused a low speed, high pressure buildup on top of the splitter for down force.
Funny you joined DSMtuners just to make your point, but at least it was to contribute some useful information.
The common notion that it's air on top of the splitter pushing down that produces downforce is in fact the opposite of what is taking place; it's air rushing under the leading edge of the splitter and into the low pressure zone residing there that is causing the splitter to pull the front end of the car down. In addition, you want the splitter's leading edge to have a rounded profile so that the air can easily wrap itself around that edge & rush into the low pressure zone at the highest speed possible, thereby maximizing available downforce.
BTW, the lines show the direction of air flow, and will disabuse anyone from thinking that a splitter actually "splits" the air forward of the car. The bow wave preceding the front of the car is forcing the air to take directions that may not be obvious.
Sorry if this is a hijack. It's just that this stuff is somewhat complicated & I wanted to share something I've learned.You must be logged in to view this image or video.
I'm afraid I haven't the faintest idea. I'd start with Georgia Tech & see if I could interest them in looking at my problem. For free. Might be worth a try.What would I need to provide to have a computational fluid dynamics-generated image of the diffuser I made and rear of the car. As I understand 2d images are much easier to produce then a 3d, but I do not currently have access to the tool. I do however have access to Blender, a 3d modeling program that I could use to made a rudimentary model of a 2G Eclipse and export hopefully to a support format for import in the fluid dynamics software.
This question goes out to the newest member dradernh, or anyone else who has access to one.
The idea just perked some interest in me
Actually, that is the story. Look at the air flow & ask yourself, how much work could possibly be being done on top of the splitter? You're stuck on the idea that the air hitting the front of the car (and the top of the splitter) is doing something of significance. With so little of it, with nowhere to go, and therefore with little speed associated with it, however, it isn't. Don't take my word for it, though - pick up a motorsports aerodynamics book & see what they've got to say.That's part of the story, yes, but the splitter also does cause a high pressure area above the splitter, which pushes down on the top of the splitter. In fact, you can see this happening in the picture you attached.
Here's another example: A rear wing produces downforce not due to the air hitting it from above after coming down from the roof, but from the air that rushes into the low pressure zone along the lower surface of the wing. In action, it's the opposite of an airplane wing (because it is an airplane wing (sort of) - it's just that it's an upside-down airplane wing). The rear wing isn't pushed down, it's pulled down; any air hitting it from above (and there is some) is insignificant as a practical matter. This is why you want a rear wing mounted behind the rear deck lid (if you have one) - if it's over the deck lid, it's trying to lift the deck lid at the same time it's trying to push it down. Better that it's trying to lift the ground up to meet its lower side, since the ground can't move.
<End of Hijack> Thanks for listening.
In case it was misunderstood, I corrected my post that the race version probably wouldn't be ready til sometime end of next year, its just my guess. This one took plenty of time WITHOUT other car projects interfering. Wait a minute.. I thought you had a DD dsm anyways, you need a diffuser for both of them; 1 street and 1 race
We'll see about testers; push come to shove people always get more timid
