- Thread starter
- #26
Ludachris
Founder & Zookeeper
- 8,880
- 4,727
- Nov 12, 2001
Newcastle,
California
Can we get a shot of a 2G in the same location to see if there's the same amount of space?
As far as you know, are the spare tire wells the same on all 2G's? It appears that's the case in the photos.Those are the best I got, hopefully someone else can contribute.
I think I have one at home... I'll have to check.I think the Chilton manual has some good underbody shots of all the models. Anybody have one handy that can check?
Yes, I'm looking at that location as a mounting point. The goal is to create a surge tank design that will fit both a 1G and a 2G with the only difference being brackets. I don't think it should be too difficult to achieve. I might be able to get a vendor interested. I just want to make it easy for them so that they can make them available at a good price.If my car was not at the trannsmission shop I would get out there and snap some off. Are you looking for a place to maybe mount a surge tank like the earlier pics in this thread Chris?
I'm working on this right now actually. Some delays because I'm out of the country for for a little bit but I should have one of these running by year end. It will be mounted in the trunk as one of the primary purposes is to gravity feed the aeromotive eliminator pump. -6 in -8 return (to tank) -12 feed to main pump -8 return from rail. Provisions for level sensor warning, temperature sensor for AEM fuel density compensation. Too bad I missed this thread until now!
I'm also going to have another line with an aeromotive shut off valve that I can open and close to drain the swirl pot back to the main tank. This is for switching fuels so I dont have to drain the swirl pot. Also a T junction/switch at the fill from the main tank so that the main in tank pump can be used to connect a hose to and pump out fuel quickly/easily. Something like a reserve tank switch except that it switches the stock in tank pump to push fuel out to either a -6 fitting or to the fill on the surge tank. That way pumping out fuel I just flip the switch attach a hose out to the jug and kick on the in tank pump
I will try to power the in tank pump off of the voltage control as well so that they both run on 9v when I am off boost to save on power consumption. At zero pressure at 12v+ I think a 255 walboro can supply the fuel required by 700whp
I may include a spare fitting for feed from an aux fuel tank for events like silver state or when using E85 and extra fuel capacity may be called for.
Wow, great information and you have great ideas! Please be sure to keep us updated, I'm very interested to see how this turns out.
Chris, you might want to consider adding some of these features like the low fuel warning and drain.
I'll look into that, but the idea is to come up with a design that can be sold to the DSM crowd at a lower price than say, Canton products. I'm not just looking for a tank for myself here, but more of a solution for all DSM road racers.Chris, contact Peterson Fluid Systems if you want a nice tank. Peterson makes some extremely nice products and best of all they are located in Colorado a few minutes away from where we live. They are reasonably priced and are extremely willing to make a custom tank. Check them out, their products are impressive. They might be able to do something about a dry sump system too.
9801 Havana St
Henderson, CO 80640
Phone: (800) 926-7867
