JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
Definitely use a restrictor if feeding from the filter housing. Bonehead also sells complete head-feed kits as well....be sure to clean out the head oil passage before installing the line as it can get loaded with crap from 17 years of being capped off. Failure to do so may send a ton of crud directly to the turbo as soon as the engine fires.My bad! I was considering the ebay bonehead lines. But I was under the inpression that its better to run the feed lines from the head, and not the oil filter housing, unless you had a restrictor
Army/Navy fittings are in 16ths. A 4AN feed line is 4/16", or 1/4". A 12AN drain is 12/16", or 3/4".Youve stated in the holset/garrett oil drain thread that the 2g oil drain is 3/4" OD and .663" ID. Which is pretty damn close to a -12AN correct?! So, wouldnt I for the time being be able to use say the top 1'' of a 2g drain with a 1" hose down to the -12 bung on the oil pan? Then once I make the switch just run a -12 bung from the holset center section?
I say do whatever you gotta do- it seems like you're on the right track for sure.
Happens more than you think. I mention in the rebuild guide to be sure to study the threads sticking out to verify their direction....any TD05H turbo can be left- or right-hand threaded.I'm in the middle of tearing down this 14b turbo. After following a few youtube video instructionals and your step by step guide on turbo rebuilds. I seem to have broken the shaft at the nut on the compressor side.
Neither will work. The eBay shaft is the wrong spec, the Evo VIII turbine turns the opposite direction.I have an ebay knock off turbo on my car currently I also have a stock evo 8 turbo sitting infront of me. Will either shaft work as a replacement?
and 13.3mm).
