Project 9's No compromise !!!
Status
Not open for further replies.
After reading another newer members build thread and seeing that other people were not only following this but actually taking note to some of the stuff I was doing I had to set a better example so I will not be bringing the car this year to the shootout because rushing a build is not the way to go and I want the car to be 100% when I unleash her. I will still be there but the goal for the car is the 2010 shootout.
Updates to come real soon !!!
Anyway enough talk back to the pictures :)
Cams installed now I just need for my 3rd gen lifters to get in and I'll throw the rollers on and i'm set. I wasn't going to get adjustable cams but seems like bc288's perform better when you advance and retard the intake and exhaust cam by 2* so that's another thing to add to the list.
I don't know if you guys caught it but I pulled a rookie move and had the thermal gasket on backwards LOL. I switched it up now but when I first got the new head I just threw everything on real quick for a pic and wasn't even paying attention. I had a nice laugh at my expense LOL
Just curious why you would put the cams in now and not wait till you get the lifters? Just seems like some unnecessary work.
If your read the vfaq about changing lifters you can change the lifters and rollers without taking the cams out and that's with them torqued down. All I did was hand tighten them. That and I was bored and wanted to see what they looked like installed. Worst case I spend another 5 minutes taking the caps off no big deal.
That's what I figured but wasn't sure.
A word of advice, if you end up taking the cams back out to put them in make sure to tighten each cam cap bolt no more then a couple of turns at a time so they can all work against the valve spring pressure together. I have broke one cam cap bolt due to tightening it too much before tightening the rest.
love the build man...good luck keep us posted!
now for my dumb question of the day...in the picture of your head with the intake mani on it whats that black box with the lines running to it for?
Is the IM/TB setup Jake hahnhart's old setup?I remember he had something very similar to that.Looking good so far
Yes, it is Jake's old SMIM and ITB setup.
The "black box" is a Golden Eagle brand vacuum distribution block with -4AN lines running to each of the individual throttle bodies, along with ports for the rest of the vehicle vacuum ports used.
If people are interested in running a vacuum distribution block, or vacuum manifold...the easiest and cheapest way is to get one for your specific application with however many number of ports or inlet/outlet diameters, etc. from McMaster-Carr.
McMaster-Carr - Vacuum Manifold
If you want to spec out a different surface finish or other parameters, here is the link:
McMaster-Carr - Aluminum Vacuum Manifold Main Menu
They are half the price of the golden eagle one, and are exactly the same.
There you go!
i figured it was for the vaccuum just wasnt sure whats its point was...thanks for the info
Exactly as twick said this is Jake's old ITB one off smim. I it performs like Jake told me this thing will surprise a lot of people with how fast it spools. The vacuums lines go to each runner to the afpr and to the BOV.
ONE DAY AWAY !!!!!!! I think this is def one of the coolest things I have seen when it comes to dsm's. TEASER PIC!!! :sneaky:
It finally came. PURE SEX!!! One Piece Carbon Fiber Driveshaft from ACPT w/ upgraded yolk for built transfercase which I will be picking up from dogboxracing in North Jersey soon. Enjoy:hellyeah::hellyeah::hellyeah::hellyeah::hellyeah::hellyeah:
I'm on my way to put her on now more pics later tonight;)
Dam wholes didn't line up. There must be different rear diff hook ups for the different years or something. Anyway we just made new wholes and was good to go ;)
Every dsm should have come like this. DEAD SEXYYYYYYY!
Hey ive been following the build, its coming along, like your determination. My motto never give up and it seems youre going foward not looking back. Great work.
Thanks yeah I'm just looking forward to the big pieces going in because then the car will start to come together big time. Next I know I been saying it forever now it seems but I have to make up my dam mind on my bottom end and just do it. Once the bottom end is done the long block will go in and then I save up for a little so I can get the transmission/transfercase setup I want. that is where the bulk of the money left to spend will go. It will probably cost about 4k to finish the drive train. That's a straight cut full dogbox trans built transfercase with bigger output and raxle front race axles. Then it's smooth sailing :)
Just to compare where I wanted to be and where I"m at
Build blueprint:
Motor: 2.2 Destroked 4g64 (STill up in the air)
Block:
94mm Eagle Crank
8:5:1 Wiseco HD1400 pistons :thumb:
Manley/MAPPerformance I beam rods
O-ringed
Felpro Permatorque HG
L19 Studs
Head:
A.R.T Inc. Stage 4 Ported Polished Head(Advanced Airflow Engineering fully ported head)
DKS 280 Cams (BC288s)
Manley Springs/Retainers (Crower springs retainers)
1mm Oversized Valves:thumb:
Bronze Guides:thumb:
JHR Custom one of a kinda ITB SMIM :thumb:
Turbo Setup:
HX52 Holset turbo:thumb:
JHR Tubular T4 Divided Manifold:thumb:
Dual 44mm Tial Vband Wastegates w/ dumptubes(On the list to get but not like I have a choise anyway LOL)
IC setup:
JHR Custom Short Route FMIC(31x12x4):thumb:
3" Piping:thumb:
Adel Wiggins Clamps:thumb:
Tial 50mm BOV(On my list to get but again not much choice anyway)
Exhaust:
4" right out the front bumper (Actually found a exhaust pipe at work today I might be able to make work with some cutting and rewelding)
Fuel:
10 Gallon Summit Fuel cell(Might just get the JMF 5 gallon fuel cell)
-10 Fuel Feed -8 return(-8an feed and return pro classic lines getting ordered this week)
Aeromotive 11102 Pro Series Pump(rated to 2000hp)(Still up in the air)
Aeromotive AFPR(Still need)
FIC Fuel Rail (-8an fittings on stock rail)
FIC New Style 1650cc Injectors(Still need)
Drivetrain:
PTT twin disk clutch((I think I'm gonna go QM but either way I still need)
DOGBOXRACING dogbox(Dogboxracing is a North Jersey company that can make dog cut gear transmissions like the dogbox everyone is used to but just cheaper)(This will be a big money item I need to save for)
Raxle Front Race axles(Still need)
ACPT Carbon Fiber One piece Driveshaft:hellyeah::hellyeah::hellyeah:
STage 5 DSS rear axles(GREAT condition 4 bolt rear with LSD will do just fine :thumb:)
DSS built transfercase(STill need)
Mickey Thompson SLicks on stock wheels and ADR 17" rims for the street(Not even on the radar right now that will be like last)
Tuning:
AEM EMS with all the bells and whistles:thumb:
Innovative wideband(Had it and sold it but they're a dime a dozen)
Tuning:
Nate from TPG Tuning(as long as he doesn't pack up and go to florida with his old friends I'm good)
SO I stayed pretty much on point with what I said I would do. Lets just hope things keep going good like this :rocks:
Great build. I have a few questions. Where did you get the driveshaft loops? Regarding the transfer case, I thought shep was the only one that made an upgraded case? Do you plan on reinforcing the rear end to handle all that power? Once again, great build.
Sean, I also am wondering where you got the driveshaft loop from -- I need one, and that one looks like a nice fit!
That driveshaft looks SWEET!
Either respond in this thread, or shoot me a PM so I can get the information and pick one up!
Thanks,
Tim Zimmer
Status
