greengoblin
Supporting Vendor
- 1,571
- 398
- Mar 10, 2006
McKinney,
Texas
For the guys that want a 6 speed. Here. If you have ddp pockets it could be yours.
http://www.albinsgear.com.au/images/products/200-close_ratio_gearbox_kits/800-evo1-3/evo1-3.pdf
I am pretty sure that an Evo 1-3 kit fits into the Eclipse and Eagle Talon.
Shipping to the U.S for the complete gear kit will be AUD$150
Listed below are the options and prices for the 5 and 6 speed kits.
I have the 5 speed kits in stock now, I don't have a complete 6 speed kit in stock – time to make the required parts will be about 10 weeks.
Mitsubishi EVO 1-3 5 Speed helical cut dog change kits.
1st 2.79, 2nd 1.92, 3rd 1.52, 4th 1.23 or 1.10, 5th 1.03 or 0.96 or 0.93 or 0.88 or 0.825
AUD$5720 – you need to supply a bare centre diff as we have to remove the standard constant gear fit a new constant gear to match with the new gears.
6 speed kit also available for Evo 1-3
1st 2.64, 2nd 1.92, 3rd 1.52, 4th 1.28, 5th 1.09, 6th 0.96 or 0.93
AUD$7675 plus the initial gear box assembly must be performed by us here as there is some machine work which needs to be done to the standard housings to adapt the new 6 speed housing to the standard gear case.
Initial assembly AUD$660 – this does not include any bearings or seals which need to be replaced.
Regards,
Haden Douglas
Sales Department
