Posi
Posi huh...yes you can swap out your diff for a quaife or similar limited slip or get a retro-fit from exile racing.
Focker420 said:
K i know this should be in drivetrain but wouldn't let me post so..
Is it possiable for me to change my drivetrain to a posi or limited slip differential?
ty Nate
Yes. Quaife makes excellent LSDs for our cars. OBX also makes them (although I hear that they don't fit very well, and are prone to grenading inside your tranny).
Then there is also the PhantomGrip/Retrofit type LSDs, which aren't "true" LSDs. They put a lot of pressure on the spider gears, and are also prone to breakage, but they cost a lot less (Quaifes cost $1300, OBX costs $500, PG costs $300). If you do get one of these, I recommend the Retrofit LSD from Exile Racing. Terry and a bunch of the other guys on 2GNT have them, and they seem to work well for the money.
I'm running one right now. It does the job on the track. I blew up my ring gear but the retrofit was totally intact. I am up and running again.
MB
