Not Valve seals! What are they?
96DSM_Steve
262
5
Aug 19, 2010
Bakersfield, California
I bought a ITM full gasket set and it came with four little valve seal look a like seals. Does anyone have any idea what they go to?
Sent from my iPhone using Tapatalk
something to do with the injectors possibly? only thing i could think that there are 4 of on the intake LOL
I too have received those seals in a few gasket kits. I am not sure what they go to. I have never found anything to actually use them for.
Look like valve seals to me, the fuel injector o-rings that go in the intake manifold are pretty thick but they are just one size, they don't neck up or anything.
You most likely got a generic gasket kit that fits a NUMBER of applications, including the 4G63. They include a shit-ton of gaskets we don't even need. I've ordered the turbo gasket kit before, and still get the header to downpipe gasket, and lots of other stuff we don't even need
This :thumb: often I get three different waterpump gaskets :rolleyes:
There should be an enclosed slip with a list of all what was included in the kit, narrow down from there :|
being that small... my best guess would be that they are "Jet Valve" seals.. a jet valve is a secondary valve for emmissions, That screwed in the head and let exhaust into the intake air charge.
The whole assembly is about the size of a grade school pencil, the valve head dia is 10mm or smaller from what I can recall
I have not seen them in a head since the mid 90's
Jet valves we common in 2 valve per cyl SOHC engines, the mazda 2.2 used them among others.
I would almost bet that those seals were in a small bag with some other small gaskets, that was then in the main part of the gasket kit.
a search of yahoo gave me this info .... if you are intrested in a part that is not used in ag63......
Jet Valves
and a pic....
so in short.... do not worry about them. and toss them in the trash.....
Glad to see you back Bogus. Makes sense. Been years since I've even seen those seals.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
