What Are They???
Status
Not open for further replies.
~laser_craver~
470
Jan 16, 2003
Montesano, Washington
ok im rebuilding an old motor for a friend of mine... 4g63 of course an i was wondering if i can reuse his old head bolts and and stuff or are they stress type thing where i can only use em once and then i gotta get new ones.... :confused:
Don't use them over again, it is just askign for problems. For 100.00 bucks you can get ARP studs and they can be reused as long as they have not stretched past there service limit.
where can i get an entire set of studs for it because its got a few broke exhaust manifold studs and intake manifol studs and if i could just get a whole kit that would prolly be easier...
There's at least one famous 9-second guy who thinks stock 1g head bolts may be better than ARP's. Other people do 30+psi on them. But, for 100 bucks for a new set, eh. 7-bolt bolts (2g's at least) are torque-to-yield, so no re-use on those at all.
Carquest here sells exhaust manifold studs for like a buck fifty apiece. Make sure to not use locknuts like the factory. Use lock washers and a nut. They don't break or turn out that way.
Status
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
