talon2gbuyer
- 1,118
- 3
- Sep 24, 2009
Aston,
Pennsylvania
Hey all, so after having a no-start issue for the last few weeks, both Brian and myself have been mulling over what this could be, and neither of us can get a real positive idea. So here is what we came to:
-all plugs generate spark
-Timing at the cam gears was spot on (cant say for sure about the lower timing marks)
-When cranking I'm sometimes getting smoke from over by the timing belt area?
-Also heard a huge POP today, sounded like a gunshot, Fuel detonation?
-ECU was checked, no corrosion at all.
- Compression:
#1 - 154
#2 - 152
#3 - 148
#4 - 140
(those are cold block results btw.. but proves it isn't a HG.)
Now this afternoon I checked the ECU and found it was damn near perfect, no blemishes of any kind. Then i went and replaced the Coolant Temp. Sensor as that can be related to the no-start issue. Still no change. So now my thinking is that the crank sensor or CAS needs to be replaced, does anyone have any other suggestions for me? I do not have access to a multimeter or I'd check injector resistance (gonna order one in a few weeks along with Link... FINALLY) and when I pulled the plugs after trying to turn her over tonite there was black fluid on the tips of the plugs as well as smelled heavily of Fuel (so im guessing I have fuel as well, although i'm going to check return line fuel pressure tomorrow to ensure I have fuel going to the injectors properly) so I guess my question is, does anyone else have any suggestions on what I should check that I have not already?
- Compression:
#1 - 154
#2 - 152
#3 - 148
#4 - 140
. Voltage will obviously check if things are receiving proper voltage and resistance will check if signals make it from ECU to sensor. If resistance is too high, then there's an issue with the wire.
